Anyone have the AISC manual 5th Edition?
I'm working on an old project and need the properties of W 6x20 wide flange. Any help would be greatly appreciated.
RE: Anyone have the AISC manual 5th Edition?
wow! Perfect thanks!
Let me know if you need anything else from the manual.
Ian Riley, PE, SE
Professional Engineer (ME, NH, VT, CT, MA, FL) Structural Engineer (IL, HI)
American Concrete Industries https://americanconcrete.com/
Alternatively you can also download the historic shape database from AISC: https://www.aisc.org/publications/steel-constructi...
Its an excel file which can be a little cumbersome to sort thru, I've made a graphical program that took the data they provided and allows you to sort by edition and shape. If you are interested in it there is a copy at the site in my signature.
Open Source Structural Applications: https://github.com/buddyd16/Structural-Engineering
As Celt indicated, the historic shape database is superior than just looking in old manuals for shape data. Older steel shapes fluctuated heavily from mill to mill and thus one WF6x20 can be slightly different than another WF6x20. If you know the era and what the shape is supposed to be you'll be conservative using the manual.
If you're field measuring the steel you'll often be better off with the shapes database and finding the closest, conservative steel shape and designing around those properties. Generally my mill designs with old steel involved lots of field measurements and lots of custom shapes input into STAAD/RISA.
Ian Riley, PE, SE
AISC also has all historic manuals available for download - at least if you are a member.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
