Contact US
Need to find Cv when it exceeds maximum stroke / opening
In a control valve CV is directly proportional to stroke of valve what happens when stroke exceeds max limit, Say the stroke of the valve maximum is 100% what if it exceeds to 110 % , with the valve fully open.
For example
Valve size %opening Cv
1" 10 0.79
1" 100 13.2
1" 110 ?
Thankyou.
RE: Need to find Cv when it exceeds maximum stroke / opening
Doesn't work that way... if its a linear CV, you probably have run out of opening area on your cage (e.g. globe valve) in the valve trim. Any additional stroke doesn't open any additional area.
BTW check your control valve position vs. CV, only certian trims are CV directly proportional to valve position
If its a quarter turn valve (butterfly or ball valve) you could actually be closing (reducing CV) when you go past 100% (Stops usually prevent this)
Jeff
Pipe Stress Analysis
Finite Element Analysis
www.xceed-eng.com
Control valve CV as stated above CAN be equal to linear travel (linear opening) or a variety of other options see http://www.iceweb.com.au/valve/control%20valves/de...
I've never seen any control valve capable of opening more than 100%. Simply doesn't happen.
There are control valves of all shapes and sizes - need to be a bit more specific.
Thank you Mr. JGard1985 , Mr. LittleInch, Actually we people in new product development doing R&D i have one last doubt
say for example
Valve type= control valve-linear opening
valve size = 4 inch
Bore= Full bore
Stroke = 2 inch
Maximum Cv= 328
Flow rate = 264 m3/hr
P1=16 bar
P2= 15 bar
My question is if stroke is changed to 2.1 inch Cv differs to 340 and flow rate also changes, and again changing the stroke to 2.25 inch Cv and flow rate remains same as 2.0 inch stroke
i.e Maximum Cv= 328
How and why @2.25 stroke the Flow rate and Cv is same as 2 inch stroke
Thank you
But what is the control valve type? Globe? Plug and cage? Ball? Gate? Plug?
Give us something to go on here.
"Full bore control valve" ?? Really?
Hi littlte inch, yes it is a Globe type full bore control valve
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
