Grease applied to Motor Bearing.
Hi Experts,
May I ask for normal equipment (point machine in railway), what are the type of grease that can be applied to the motor bearing?
Information:
Equipment placed: Viaduct
Temperature: Could be around 25 to 45 degree
Environment: Normal/High vibration due to train passes
Please let me know if you require more information.
Thanks.
RE: Grease applied to Motor Bearing.
Done a few of them in cold Sweden. Ice in the switches/points is the problem we have here. Normal grease used. They shouldn't operate very often - if it isn't a switch-yard. I do lots of bearing problems but have never seen any problem with the grease in these applications. And the infrequent operation may be a problem since the oil film will flow away under the static force. The balls may then be "hammered" into the raceway and make (small) dents if vibrations are severe. Klüber may have a good answer to your question. They have all sorts of special grease.
Gunnar Englund
www.gke.org
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
