Hi there,
I am looking to replace a pressure gauge for a 2 MPa laboratory water pressure vessel. This will require me to disconnect the existing gauge from the integral piping, before the new one is replaced. Will the system then need to be re-certified by a registered pressure vessel inspection body? Or can I carry on using the system since this has not modified the actual pressure vessel itself?
Any advice on this is greatly appreciated - it is not my area of expertise.
