UT can be made only by dismounting the PV, and depends the height of the skirt because you can only access with hands (like a handhole, no manway). Also depends of nozzles in the head.
Visual inspection: same as UT.
Small diameter PV can be mounted on structure (no skirt, no legs)
r6155
