SKJ25POL
- Mar 4, 2011
- 358
I heard anchor bolt chair is used for tanks.
1- What's particular with tanks that requires these type of anchors?
2- Why the above ground portion of the anchor is longer than normal anchors for column base plates?
3- Is the chair anchor bolt only used in steel tank foundations? What types tanks require chair anchor bolts?
4- where can I find some design examples?
Thank you very much,
Skj
Skj
