MEP Naming Conventions
Working on schedules for P&ID and building systems, I am looking for a copy of NCS , if anyone can spare.
also looking for acronyms/abb. for " INSTANT HOT WATER DISPENSER" and "ELECTRICAL SUB-DISTRIBUTION PANEL ".
I would appreciate any help.
Thank you
Windseaker
What is so wrong with a check and balance system! Money vs Life
RE: MEP Naming Conventions
OK....
LET TRY THIS:
Boil-on-demand, Hot water tank dispenser,Tank-less water heater, OR THE BIG ONE [Point-of-use (POU)]
LAST ONE
INSTANTANEOUS WATER HEAT (IWH): (2014 VA PLUMBING Abbreviations)
Any Thinkers, or Takers
anything is helpful....
windseaker1,
John H. Dunten, CD
Certified Drafter
What happen to using this:
NCS (National Cad Standards) UDS, CSI.
Does NCS have a naming convention?
Since the National CAD Standard is focused on the delivery of architectural information, it's probably best to pursue this question in an architecture forum. This forum is primarily dedicated to factors affecting dimensioning and tolerancing with some dealings with mechanical engineering drawings. There is approximately zero overlap between the two areas.
The current version, 6, is available at https://www.nationalcadstandard.org/ncs6/ordering....
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reliability Verification for AI and ML Processors
Artificial intelligence and machine learning are seeing growing adoption in a wide range of applications. ICs used for AI/ML applications are characterized by large parallel processing computation units, high power dissipation, and complex circuitry that can deliver maximum performance within a strict power budget. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
