MEP Naming Conventions
windseaker1
Working on schedules for P&ID and building systems, I am looking for a copy of NCS , if anyone can spare.
also looking for acronyms/abb. for " INSTANT HOT WATER DISPENSER" and "ELECTRICAL SUB-DISTRIBUTION PANEL ".
I would appreciate any help.
Thank you
Windseaker
What is so wrong with a check and balance system! Money vs Life
OK....
LET TRY THIS:
Boil-on-demand, Hot water tank dispenser,Tank-less water heater, OR THE BIG ONE [Point-of-use (POU)]
LAST ONE
INSTANTANEOUS WATER HEAT (IWH): (2014 VA PLUMBING Abbreviations)
Any Thinkers, or Takers
anything is helpful....
windseaker1,
John H. Dunten, CD
Certified Drafter
What happen to using this:
NCS (National Cad Standards) UDS, CSI.
Does NCS have a naming convention?
Since the National CAD Standard is focused on the delivery of architectural information, it's probably best to pursue this question in an architecture forum. This forum is primarily dedicated to factors affecting dimensioning and tolerancing with some dealings with mechanical engineering drawings. There is approximately zero overlap between the two areas.
The current version, 6, is available at
