Engineering properties of composite material CFRP
ABD01
MD
Hi
I am looking for the Engineering properties (E1, E2, E3,,,G12, G13, G23,) of CFRP Laminates of E1 around (+/- 10%) 200GPa.
You may suggest a Material database website or Mat library built-in software or from your experiences, if you run into a paper used such material.
thickness=1.4mm, E1>200GPa, Ultimate tenisle strength 2400-2600Mpa , elongation =1.3%
I am searching the literature but I have not had luck yet.
Is there a way to search the database of the specific journal website
I posted here as I feel you mostly need these properties when you conduct Numerical analysis. I check the material forum and found such questions have not been answered.
I would think the properties would vary for every supplier.
Most material supliers post datasheets with basic properties on their web sites.
I have seen that type of data in design manuals. But I would contact i material supplier.
It is also a question of how you intend to use the data. FRP is a "built-up" material with layers. The orientation of the layers is an important factor. Perhaps you only intend to use a single layer.
I would start with Google [smile]
Good Luck
Thomas
