13Cr WELDABLE MARTENSITIC STEEL
Goodday Everyone,
Please, any one that have been involved in the welding of a gas line of pipe material: 13Cr weldable martensitic steel. I will sincerely appreciate your advice and if possible any draft pWPS that could be of help and guide. I have had suggestive inputs from senior colleagues but I need advice from someone who has practically been involve in the welding of 13Cr weldable martensitic steel gasline.
Thanks sincerely
chitessy
Thanks sincerely
chitessy
RE: 13Cr WELDABLE MARTENSITIC STEEL
I suggest you call in an expert welding engineer possessing actual experience with this alloy.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
https://www.eng-tips.com/viewthread.cfm?qid=431675
Both may contain some interesting information.
Some basic stuff and depending on code: You will have to maintain an interpass weld temperature around 400-500F and then you'll have to PWHT at around 1380F . Matching filler will work but having something with a little more Ni in it would help stabilize the Austenite before it transforms to martensite on cooling, giving you less ferrite. The high Cr to low Ni will make ferrite come out quite a bit and generally you don't want to exceed 20%, otherwise your toughness will drop.
Also, typically, I think people do a GTAW root pass and then fill it up with SMAW.
Hope that helps at lease a little,
absolutely Not
Could you explain why not PWHT?
Are you assuming his is talking about 13-4? which I would understand is a ferritic steel.
I guess I was was thinking more along the lines as 410, which I know they use in the oil/gas industry.
13-4 aka CA-6NM aka 415 is unlike all other martensitic stainless grades.
For more info you will need to google.
Thanks to all for all your inputs. The material in question is SEAMLESS STAINLESS STEEL LINE PIPE 13%CR-2.5%MO. We will have to put up a pWPS, and carry out the procedure qualification process to see what happens.
Thanks to all
Chitessy
I would expect the response to heat treatment and the welding issues to more like those for 410SS.
I would contact the pipe manufacturer and perhaps a weld consumable supplier for specific fabrication advice.
When you get the carbon low enough for weldability they hardly form any martensite.
Does your procedure require passing impact toughness? at low temp? That is often the hard part.
Just like you suggested, we were able to get advice for the welding consumables.
EdStainless (Materials)
For this procedure, impact toughness test is not required.
Thanks All
Please refer this link below. Welding of this steel with all pros and cons are well explained. Best properties in welding of this steel are achieved,with matching welding electrode and adopting PWHT.
Thanks.
http://www.metrode.com/SiteData/en-gb/File/410%20T...
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
ca.linkedin.com/pub/pradip-goswami/5/985/299
