Contact US
Dry Gas Seal Performance Tests
Hi everyone,
Are there any standards or recommended practices describing procedure for dry gas seal performance evaluation? the shape of test rig? and the limits on which the tests are acceptable.
I have a log sheet for dry gas seal test by John Crane, but the procedure is not explained
What could be measured, must be measured exactly.
RE: Dry Gas Seal Performance Tests
Essentially, your company will have an inspection test plan.
If none is available, then follow the OEM test plan.
Contractually, the OEM must provide you the document. Do insist on having it for reference and review.
What you see on the log sheet is data measuring speed, temperature, time, load, test pressure and leak rate. (static and dynamic)
You should also have a drawing or specification where John Crane provides a guarantee, and the accepted deviations.
There is no standard for the test rig. Normally, we will accept the OEM setup as it is.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
