ANSYS Workbench composite structure stress output
So I have a composite laminate structure with wall thickness of 2 mm and maximum dimension around 600 mm. Material model is fully orthotropic with 9 elastic constants defined and fabric is assumed to be symmetric (E1=E2). Structure is modelled using shell elements and loaded with pressure and acceleration. I'm reading directional Y axis normal stress on a single ply (in ply coordinate system) and it turns out the minimum value is lower than the minimum principal stress. The difference is about 0.3%. These values are not on the same node but are on the nodes that are next to each other and both on the edge of the structure. How is this possible that directional stress has larger magnitude than the principal one?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
