Bystronic 2800 problem
I have a problem with 1995. Year bystronic 2800 computer. Keyboard is not working. INIT button works and HAND button when i push it 2 times. Thats all. Other buttons not work.
RE: Bystronic 2800 problem
If the keyboard itself checks out then the controller for it might be the problem. Check it for loose solder joints. if you don't find anything and the keyboard buttons all check out then it's most likely a bad keyboard controller, keyboard to sercom cable or sercom board
if you are in north america txt me 706-627-7854 I might be able to find you used parts if you need them. I build conversions for these lasers that run Win XP.
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
But thanks for help Krugtech!
