Presumptive Load Bearing Values
geomane
Geotechnical
How are the presumptive allowable lateral pressures calculated in the IBC?
Sand, for instance, is 150 psf/ft. Is this calculated from the passive pressure divided by a safety factor?
Not sure what IBC is thinking; but if sand is 100 pcf with Rankine Kp of 3.0 for phi = 30 degrees, and with a SF = 2.0, pp = 100 x 3.0 / 2 = 150 psf/vf. Probably conservative.
