Aircraft Moments of Inertia Analysis Report
Dear All,
I looking for something guidance document on preparing a mass moments of inertia analysis report, that compares what changed between two different aircraft based on mass changes happened between them. Any tips or links please?
Thank you much...
RE: Aircraft Moments of Inertia Analysis Report
it's just "simple" data isn't it ?
you may get into trouble if you're changing payload and installed equipment, if you're trying to compare.
if commercial you need to consider partial payloads and people moving around the cabin, some call this the "potato" diagram.
You will need to be clear about what is accounted for where (under which heading) ...
Basic empty weight is a very basic airplane, often without an interior
Minimum flight weight has the minimum (duh!) added, like flight crew and unusable fuel and oil.
Operational empty weight would add the interior (including seats) and more crew and fuel reserves.
Max Zero Fuel weight (with is a type restriction) adds so much payload
Max take-off weight adds fuel
You need these weight distributions before you can calc mass moments.
You're modifying an existing plane ? you should be able to get the mass distributions for the unmodified plane and then calc the mass moment, and then your modified plane's masses and then mass moments.
Some more clues as to what you're doing (and why) would help.
Thank you rb1957 Sir, but the mass moments are from the aircraft global CG?
Basically looking to compare before and after moments of a helicopter, and then somehow use the difference information to find effects on life limited parts.
Society of Allied Weight Engineers [SAWE] may have useful information on this subject...
SAWE Introduction to Aircraft Weight Engineering
https://www.sawe.org/technical/publications/aircra...
SAWE RP-6, 1999: Standard Coordinate Systems for Reporting the Mass Properties of Flight Vehicles
https://www.sawe.org/technical/rp/sawe_rp-6_1999
SAWE RP-7, 2004: Mass Properties Management and Control for Military Aircraft
https://www.sawe.org/technical/rp/sawe_rp-7_2004
Regards, Wil Taylor
o Trust - But Verify!
Some data specific to a rotorcraft (Bell 412 / UH-1Y) can be found in this paper:
http://pubs.casi.ca/doi/pdf/10.5589/q02-021
(I only ever had the paper copy.)
No one believes the theory except the one who developed it. Everyone believes the experiment except the one who ran it.
STF
"the mass moments are from the aircraft global CG" ...
yes, at the end of the day you want the mass moment about the CG, but to get there you sum masses and their moments about a datum point to determine the CG location. just like calculating the centroid of a section (1st and 2nd moment of area).
Also, may be useful...
SAWE-P-3020 MEASURING MASS PROPERTIES OF AIRCRAFT CONTROL SURFACES
https://www.space-electronics.com/contentAssets/Li...
ASD-TR-79-5004 Inertia Calculation Procedure for Preliminary Design
www.dtic.mil/dtic/tr/fulltext/u2/a072679.pdf
Regards, Wil Taylor
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
