I temID length 30 char or 32 char ?
Hi
When I trying to create new item ID with
30 char "123456789012345678901234567890"
Its OK but when I trying 31 char
"1234567890123456789012345678901"
Its not OK. (Refuse to save)
But in other hand when I browse the
Nxmanager I see items IDs with 32 char
Ny question is if in my journal I use
32 char do I can be sure nothing bad
Can happen. ?
Thank you.
RE: I temID length 30 char or 32 char ?
It All depends on what naming rules have been set by your Teamcenter Administrator.
The item id's with 32 characters in the database might have been created by a dba (override) or a special group which has the rights to do this.
Just try it if your code can create an item with 32 characters. nothing bad will happen.
It would be best of course to try these kind of things in a dedicated test (QA) environment. There should be such server/environment available for you. Ask your Teamcenter administrator.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Hi Ronald thank you for your suggestion help.
I think I stay with 30 char.
Its more safe for me.
Thank you.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
