Microsoft VB for Applciation - XML file Result skip the else statement.
Hi Guys,
I have this vb code : -
However the XML result doesn't go to the else statement, keeps on repeating the If and calls the WriteHeaderStart(a). Can anyone help?
If LineCode <> NextLineCode Then
Call WriteHeaderStart(a)
SequenceNumber = 1
Call WriteSubLine(a)
NextLineCode = Worksheets("Entries").Cells(Itemrow + 1, 1)
Else
SequenceNumber = SequenceNumber + 1
End If
If NextLineCode <> LineCode Then
Call WriteHeaderEnd(a)
NextLineCode = ""
End If
Itemrow = Itemrow + 1
SequenceNumber = 1
Else
End If
NextLineCode = ""
End If
RE: Microsoft VB for Applciation - XML file Result skip the else statement.
Edit... And the initial value for the NextLineCode variable.
