meshing techniques
If those are 3 noded triangles DON’T use them. Awful.
Any competent preprocessor can auto mesh that area. You may need to specify 5he number of nodes on each edge.
I admit I have a complex geometry, but the software is not so smart as I supposed. Any mesh I tried leaded me to a non-convergence result, except for the structured triangular one. However I don't really like it very much cause there are some distortions. The mesh I uploaded according to me is the best one cause is the most regular or, either, a square one with triangular elements on le long edge
Triangles are ok if you use midnodes. Without midnodes you can overestimate stiffness.
What is preprocessor you use?
Or try to make quada at center.
mesh the area with triangles as the default element.
use the mid-side node option (as others have suggested, 3 noded trias are not very good ... but try this for yourself to see)
as others have suggested, using quads is typically "better".
you also don't "Have" to use a uniform mesh, depending on the loading, etc.
btw, "half square" made me think of rectangles. "triangle" or more precisely "right triangles" would be a better term (IMHO).
Depending on your pre-processor you should be able to get the result you want. This is from Femap with mapped meshing and tri-elements. Some tweaking should fix it if needed.
Good Luck
Thomas
You should also be able to partition the face before you mesh it. You can just draw the vertical and horizontal lines.
