i wanted to make a program in nxopen that can check and move all objects to specified layer range
Henth
Aerospace
IN
Hi everyone,
i wanted to make a custom nx journal that can move
all sketches,text,curves to 50-100 range
all fixed datum planes,datum axes to 101-120 range
the main datum csys (that is visible right after opening nx and choosing to make a model) to 200
solids and extrude,edge blend or face blend to 2
format,legends to 240
drawing sheets to 255
suppose if there are like 10 datum planes and 3 axes, after running the program they should have layer like 101,102...110 for datum planes and rest of axes should have like 111,112 layer numbering.
can anyone help me in making the program?
Thanks in advance!
And how should the program decide which Datum plane to put on which layer?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
