Contact US
moving pressure vessels- same service
Management wants to relocate small process plant with a number of pressure vessels to different location. All vessels will be in exact same service. They also want to inspect all vessels via API 510 before re locating.
another prevailing thought being proposed is the vessels should be inspected after re location. Not sure if this would come under 579 FFS since service is exactly the same.
Just seeking the wisdom and input available via eng-tips
Lee
RE: moving pressure vessels- same service
IMO, API 510 and API 579 are for two different purposes. It's the Mgmt decision if the vessels to be inspected either before or after relocation and types of inspections, which may involve the issue of the project cost center.
Will the pressure vessels be moved to a different State ???
MJCronin
Sr. Process Engineer
Changing locations may change the wind or seismic loading also.
to MJCronin (Mechanical)
Vessels will be in same state. Actual less than a mile from current location
Thank you
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
