Post yield stiffness ratio
umeshlamichhane
NP
how can we assign post yield stiffness ratio in flexural hinges of beam in sap model?
Never done that, but it seems that for hinges on beams one can use/SAP2000 uses tables from say FEMA365 (use axial force vs disp. curves or moment vs rot. curves). See this video for details: Link
I found also this document that explains how these curves are defined by SAP. Search for this on the internet: Test Applications of Advanced Seismic Assessment Guidelines
You can probably define your own curves also.
The post yield stiffness ratio I only found info for rubber isolators :) (so not for beams)
Hope this helps
