How many of you know Laplace transforms?
Why do I ask?
I was on a Chinese hydraulic servo forum. There is an on going dispute about different kinds of servo control. The problem I have is that no one understands Laplace transforms.
I can show the relative strengths of PID, PD, PI and P only control using Laplace transforms but no one seems to understand Laplace transforms, transfer functions, time constants and bandwidth. A common problem we have in China, and even the EU, is that people not aware of even the basics of how to control a hydraulic servo system or to select cylinder diameter and valve size.
A second question.
Many of you know that I write magazine articles related to hydraulic servo control. Are there any topics you would like me to cover?
A second question.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
http://forum.deltamotion.com/
RE: How many of you know Laplace transforms?
After that they appeared again in the Automatic control theory class.
Also Bode diagrams, Nyqvist diagrams.
Keith Cress
For me, I'd say that a basic understanding of back pressure in hydraulic lines would have resolved the most costly problems.
What percentage of hydraulic systems don't have a human operator closing the position and velocity loops?
What I want to know is that if anybody could ask intelligent questions about this simple example using a P only control for a hydraulic actuator.
http://deltamotion.com/peter/Mathcad/Mathcad%20-%2...
On the first page I show how to generate the closed loop transfer function for a hydraulic actuator using P only control. Then I find the actual and desired characteristic equation . Does anybody follow this?
Should I do this here on this forum or on my own?
It depends. Mobile equipment still is largely manual control. Industrial equipment is very sophisticated now and mostly computer controlled. If the industrial equipment isn't computer controlled it soon will be.
Peter Nachtwey
I think the difficulty many people will have is that they'll study Laplace in university, but if they don't have cause to use it during their work then over time it will fade into unfamiliarity. I imagine that calculus suffers the same fate for many practicing engineers.
I am a moderator on a Chinese hydraulic website. What I can say is that in China they have far more hydraulic schools that in the US. They teach hydraulic in the universities. I know. I have been there and have given presentations. However I don't think the universities there are any better than the universities here or even as good. It doesn't seem to make a difference where we go, US, CN, or EU the engineers learn Laplace transforms if they math students or EE students. This was mentioned above. The sad thing is they the students instantly forget what they have learned. This seems to be universal.
No I can't say universal, just global.
I am stuck. I can't make a point. I was hoping to find 1 person that really knows Laplace transforms.
Peter Nachtwey
GSTP
Graduate Mechanical Design Engineer
UK
TTFN (ta ta for now)
@Everyone, if you want to see Laplace transforms used for control theory then visit my Peter Ponders PID YouTube channel. Warning, most people stop watching after 3 minutes because they don't understand Laplace transforms and control theory at that level.
Peter Nachtwey
I don't think we instantly forget, but it's inevitable that it fades over time through disuse. I understand enough of it to be able to pick it up faster than someone who has never seen it before, but in the last 25 years I've had no practical use for it either.
I imagine some of the engineers such as yourself who actually design turbine governor servo controllers know Laplace inside out. I have to operate and maintain what guys like you have designed alongside the myriad other powerplant systems I have to operate and maintain. I'm unlikely to ever be an expert in any of them, but I have to know a reasonable amount about almost all of them. You're at the other end of the spectrum in a role where you can specialise in one field and truly master it.
There optimal proportional gain, Kp, is calculated symbolically. The optimal value for Kp is a function of the open loop gain, natural frequency and damping factor. This really shows that the performance of a servo hydraulic system using proportional only control is all up to the hydraulic and mechanical designers, not the person adjusting the proportional control.
Peter Nachtwey
3rd from last equation appears to be truncated.
simplification for position equation
derivative of position to get velocity, presumably.
Notice that that pos(t) is making a step change in position r. This can be any distance that doesn't saturate the control output. Notice that the error decays as a function of ⍺. r can be 1mm or 10mm it will still take 5 time constants to move within the set point r. The time constant is the inverse of ⍺. ⍺=2*ζ*⍵/3 so 5 time constants will take 7.5/(ζ*⍵).
The point here is that the shortest time constant is determined by the damping factor and natural frequency and these are determined by the hydraulic and mechanical designer. There is NOTHING the control person can do to optimize the proportional gain, Kp beyond the formula.
I just want to cover proportional gain only control but one should ask if the optimal time constants are determined by the natural frequency and damping factor for PI, PD or PID control? The answer is yes. Are there control algorithms that get around the natural frequency and damping factor limitation? The answer is yes. More on this at another time.
So good so far. Now on to page 4.
Do you agree with the calculation for the time constant?
You can see the step response reaches within 1% of the set point in the predicted amount of time.
Peter Nachtwey
The damping factor is determined by the hydraulic and mechanical designers. The control guy can't do much with proportional only control. The question that can be asked is "does adding a derivative gain help". What about a PID? I have done the same calculations with a PID too. The point is the damping factor and natural frequency determine how errors will decay. The hydraulic and mechanical designers really determine limit of how fast the errors will decay.
Is there a solution? Yes, but not with a P, PI, PD or PID controller.
Peter Nachtwey
Agree, there are supposed to be solutions using brute force approaches.
I can't say more because it would be considered advertising but look for recent articles on the magazines.
You can also e-mail me. My e-mail address is not hard to find.
On top of that you can alway watch my "Peter Ponders PID" videos. The videos are for the advanced users.
Most people give up after watch about 3 minutes because they don't understand the basics.
Peter Nachtwey
