Design a force on a T-Beam section
csingh000
I am trying to add a force on the tip of the beam angled on the T-section. I am able to draw the actual beam in 2D, but would I create the T-shape in the frame section designer? How could I angle a force on it? I have attached a picture to describe my issue.
 https://files.engineering.com/getfile.aspx?folder=42b71802-9f73-4bf9-8a05-b8a0b613f629&file=Capture.PNG
Knowing the angle, resolve the force into the vertical and horizontal components. Apply these in the model to represent the angled load. You cannot directly input a load on an angle, you need to resolve it into components to be consistent with the coordinate system being used.
