expansion joint connection.
malikasal
130
hey
is there any recommendation in any reference to use an X bolt in lieu of M bolts in shear tabs sliding joints.
ôIf you don't build your dream someone will hire you to help build theirs.ö
Tony A. Gaskins Jr.
Do you mean M bolts (metric)? Or N bolts (threads not excluded from the shear plane, the opposite of X bolts)?
sorry Lomarandil, i meant N Bolts.
Tony A. Gaskins Jr.
I don't think that shear tabs with slotted holes are appropriate for use in sliding joints.
These joints are prone to cramming with debris, or rusting solid such that the slide you expect won't be realized.
I would recommend looking into a sliding joint using a teflon bearing pad, and looking up
I believe that there was a significant structural collapse based on this detail, but the name of the structure alludes me at the moment.
Once20036, I believe you're referring to the parking garage floor that collapsed in a convention center in Pittsburgh. News article linked below. There is some security camera footage of the collapse somewhere online, but don't have the time to find it right now.
