S355 J2G3 STEEL EQUIVALENCE
Hello friends,
Can you please tell me which is the equivalence on ASTM of S355 J2 G3 steel??
I found a link which sayed it is A575 GR50. Is it correct?
Thanks for a fast fact check!!
RE: S355 J2G3 STEEL EQUIVALENCE
I think you will find that S355J2G3 is an old designation (EN10025:1990) which was replaced in 2004 with S355J0. If you want an equivalent then it has a yield of 355MPa and guaranteed impact properties (Charpy test) of 27 Joules at zero degrees Celsius.
An ASTM equivalent would be A572 Grade 50 which has a yield of 345 MPa but you would need to invoke supplementary clause S5, and state requirements, to get the impact properties.
The J2 means 27J @ -20°C, J0 means 27J @ 0°C. Couldn't immediately find the meaning of G3, have to search in my old standards.
Yield = 355MPa, the S stands for Structural steel.
Correct that the J2 has been replaced with J0, however I'd still search for something with 27J @ -20°C, just to be sure... Can't be too hard.
S355J2G3 was defined in EN 10025:1990.
J2 : a minimum Impact Energy of 27 J at -20°C (Charpy-V-specimen in longitudinal direction, average of 3 values)
G3 : the delivery condition is normalized for flat products (plates, coils, sheets). For Long products (sections, bars,..) the delivery condition is at the discretion of the manufacturer unless otherwise agreed.
In EN 10025-2:2004 S355J2G3 was replaced either by S355J2+N for flat products or by S355J2 for long products.
Thanks friends, great info.
I will make sure to test impact properties from the material I will use to replace S355...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
