Can anyone help me identify which material is better?
I have 2 different steel material and got them both tested and following are the results. However I am not sure which steel is better from both of the comparison. If anyone can help me out to identify it, I will really appreciate it.
Sorry for the bad quality. (Pic Also attached)
Kind Regards,
RE: Can anyone help me identify which material is better?
It depends on what the application is. More information needed before you start getting meaningful responses.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
Thank you for the prompt reply.
Actually it is a gear part of a harvester. And the material is different from the original and I am trying to figure out which material is better in terms of strength, wear and tear etc. Or in general if we compare each other which material is superior?
Can you please let me know what else details I can provide? thanks
ALso, does the material composition also affect the price? can we determine which material is more expansive or cheaper just by looking at this composition?
I would imagine that Sample A is more expensive based on it's slightly higher chromium content and the addition of nickel.
Are these the only elements they tested for or are these the only significant elements they found out of a more extensive test? Was each sample only tested once? Did they give you any error estimation for the expressed values?
Edit: Also, given that these are each steels, it would be possible to heat treat them and change the mechanical properties. This would have a significant impact on the cost as well as which is "better".
Aidan McAllister
Metallurgical Engineer
Steel B can be heat treated to higher hardness, but not in thick sections.
Steel A will heat treat deeply and likely have better toughness, but not quite as strong or hard.
Cost, manufacturing and heat treat methods, part size, and required properties are all important to consider.
Is there any welding involved? That should also be considered.
If it is a gear then you will want characteristics appropriate for case hardening (if I can make that assumption).
ASM Handbook is an excellent reference.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
OP said " the material is different from the original."
What is the original material?
Did it perform acceptably?
If not, what was unacceptable about it's performance ?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
