ATEX Certification - Manometers & Thermometer (liquid expansion)
odnaz
SE
Dear All,
I'm new in this forum, hope to be able to help with my replies and I'm sure I'll get help from you!
At the moment I have a problem related to pressure indicator (manometer, mechanical) and thermometer (expansion fluid, very basic type): do they need really an ATEX approval, is it necessary for both cathegories?
Thank you!!
If they are not capable of causing an explosion by acting as a source of ignition, they shouldn't need ATEX approval. Based on what you stated, I'd say no.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
If they're stand-alone indicating devices then probably not. If they have switching contacts for alarms / trips then they'll need certification.
