normally consolidated or over-consolidated
Hi All,
Is there any way to tell if the soil is over-consolidated or normally consolidated just based on Atterberg results, moisture contents, SPT N-values and pocket penetrometer?
Thanks for your answers,
RE: normally consolidated or over-consolidated
other than sensitive marine clays, if the water content is at the liquid limit, that's typically reflective of normal consolidation.
in marine clays, it can be a bit different. If a pocket penetrometer shows undrained shear strength different than some Su/P' ratio, it could have some stress history? Certainly can't go by blow counts in sensitive marine clays!
f-d
ípapß gordo ainÆt no madre flaca!
Thanks fattdad
Hey Silty look up the following it is a good resource for correlating any field or lab test to soil properties. Its a bit dated but you can track down more recent correlations by reviewing the citations and who's been citing them.
Manual on Estimating Soil Properties for Foundation Design
August 1990
Be careful with oven dried moisture content. If soft clay is likely to be encountered, go CPTu/DMT. SPT and pocket penetrometer are crude for soft clay/silt.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
