Tmoose
- Apr 12, 2003
- 5,636
A customer reports the steel worm wears at a rate of about 4-1, so we have sold them 4 worms that fit fine, but now need a replacement worm gear for their coal stoker drive.
The original drawing dates from 1922, so it seems likely we have supplied a successful worm gear or two over the years.
The new worm gear reportedly does not mesh with the worm we provided. I will find out more about exactly what that means.
As a start, Does the attached drawing contain all the info needed to make a worm gear?
I am questioning the lack of "helix angle," but am a complete novice in this gear stuff.
Also, the reading I have done suggests I need to ask the machine shop if the worm gear is crowned, and if they used a hob, what the diameter of the hob is, as a worm gear/wheel made with a hob with the identical pitch diameter as the working worm is crownless, and is very difficult to assemble.
thanks,
Dan T
thanks,
Dan T
