Software similar to WoodWorks Connections
Hello Everyone,
I am currently looking for a design program similar to WoodWorks Connections. The program is great and handles what is asked of it. The speed at at which different nailing configurations can be assessed is very appealing and makes for a great resource. Also the user interface is nice, quick, and simple to use. The only problem is, I think the program is only allowing configuration based off of traditional wood screws. The only other options for the connection types consisting of bolts and nails. I would like to be able to have the same control and speedy access to screw spacings that the WoodWorks program provides but with more options for wood screws like the Simpson String-Tie Strong Drive Timber Screws, or similar products. If anyone has some suggestions for programs that has a similar user interface but allows for different screw options it would be greatly appreciated if those recommendation would be left below.
Thank you.
RE: Software similar to WoodWorks Connections
Talk to the vendors of the products you want to use. Simpson has a connection selector, for instance. It's standardized arrangements, but gives some assistance.
https://www2.strongtie.com/software/connectorselec...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reliability Verification for AI and ML Processors
Artificial intelligence and machine learning are seeing growing adoption in a wide range of applications. ICs used for AI/ML applications are characterized by large parallel processing computation units, high power dissipation, and complex circuitry that can deliver maximum performance within a strict power budget. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
