IS IT ALWAYS MANDATORY TO APPLY NOZZLE LOAD ON STANDARD FLANGE AS PER LATEST ASME?
In the light of latest ASME, Is it mandatory to check standard flanges against nozzle load. In this way most of the time flange rating will increase and every time we have to inform piping department to increase flange rating.
IF A DATA SHEET DOES NOT SAY TO CHECK APPLY LOAD ON FLANGE, EVEN THEN WE HAVE TO APPLY LOADS ON FLANGE???
RE: IS IT ALWAYS MANDATORY TO APPLY NOZZLE LOAD ON STANDARD FLANGE AS PER LATEST ASME?
Please avoid all capitals. It is distracting.
What do you consider a "standard flange"?
What "pressure vessel" is the "standard flange" attached to, and why do you believe some loads on some flanges (instead of every load on every flange) be should not be checked?
I don't know about the ASME but in the European EN 1092 for standard flanges you must consider some minimum external actions on flanges (En 1092-1 Annex A)
Which "ASME" do you have in mind?
Mike
I don't see how a purchaser can over-ride a mandatory provision (as confirmed by Interpretation VIII-1-16-85).
Nevertheless - apply Code Case 2601. Up-rating flanges shouldn't have to be done in most cases.
TGS4,
Code case 2901 is specific to weld neck flanges. Do you know if anything is in the works for all of the other flange types? (LWN / slip-on / lap joint / etc...)?
Cheers,
It would be applicable to LWN. There hasn't been any research done yet on slip-on or lap joint flanges.
Btw, the provisions of the Code Case will be incorporated into UG-44.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
White Paper - Medical Device Design Control
Medical device product development is a highly integrated and regulated process. Implementation of a requirements tracking solution requires attention to a variety of nuanced topics. When presented with the task of tracking the many concept relationships in a project of this type, the initial software solution of choice tends to be a two-dimensional text systems. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
