Journal to create reference set
Hi
When I run a journal that create
a ref set the components are added automaticaly.
Because of my session preference default.
How I can save set and restore this prefernce so the created ref set do not
Add comonents automaticaly.
Thank you.
RE: Journal to create reference set
The journal is gtac ecample that use
Asem.createrefset
CODE -->
mports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module make_ref_set
Sub Main()
  Dim s As Session = Session.GetSession()
  Dim ufs As UFSession = UFSession.GetUFSession()
  Dim origin(2) As Double
  Dim matrix(8) As Double
  Dim ref_set_tag As NXOpen.Tag
  Dim cntr As Integer
  Dim disp_props As New NXOpen.UF.UFObj.DispProps
  ufs.Mtx3.Identity(matrix)
  Dim all_bodies() As Body = s.Parts.Work.Bodies.ToArray()
  Dim body_tags(all_bodies.Length - 1) As Tag
  For i As Integer = 0 To all_bodies.Length - 1
    ufs.Obj.AskDisplayProperties(all_bodies(i).Tag, disp_props)
    If disp_props.layer = 1 Then
      body_tags(cntr) = all_bodies(i).Tag
      cntr = cntr + 1
    End If
  Next
  ufs.Assem.CreateRefSet("MY_REF_SET", origin, matrix, body_tags, cntr, ref_set_tag)
  If ref_set_tag <> NXOpen.Tag.Null Then
     MsgBox("ref_set_tag: " & ref_set_tag.ToString)
  End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
  GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
You can use the .SetAddComponentsAutomatically method on the reference set object to set whether components are automatically added or not.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Create New Reference Set")
Dim referenceSet1 As ReferenceSet
referenceSet1 = workPart.CreateReferenceSet()
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Add Components to Reference Set")
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Name of Reference Set")
referenceSet1.SetName("test1")
referenceSet1.SetAddComponentsAutomatically(False,False)
Dim nErrs2 As Integer
nErrs2 = theSession.UpdateManager.DoUpdate(markId4)
theSession.DeleteUndoMarksUpToMark(markId3, Nothing, False)
End Sub
End Module
www.nxjournaling.com
Cowski thank you.
But in ghe gtac example their is not yet
a refset exsist and the new created
Refset grab all components.
If I want to usse uf functions only
Is it passible.?
Thank you again.
If you want to use the .CreateRefSet method, you can turn off the components option after it is created.
CODE
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module118
    Sub Main()
        markId2 = s.SetUndoMark(Session.MarkVisibility.Visible, "Create New Reference Set")
        Dim cntr As Integer
                cntr = cntr + 1
            End If
        Next
        Dim myNewRefSet As ReferenceSet = Nothing
            myNewRefSet = Utilities.NXObjectManager.Get(ref_set_tag)
            myNewRefSet.SetAddComponentsAutomatically(False, False)
        End If
    End Sub
    End Function
End Module
Cowski thank you very much.
You helped me to make it pure UF functions.
CODE -->
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module create_ref_set_of_all_solid_bodies_on_layer_one
    Sub Main()
        Dim cntr As Integer
                cntr = cntr + 1
            End If
        Next
            ufs.Assem.SetAutoAddNewComps(ref_set_tag, False)
        End If
    End Sub
    End Function
End Module
I'm curious why you want to use ONLY the UF functions? That seems like an arbitrary and possibly very limiting constraint.
Bcause the referece help doc
Of uf is more descriptive
And not a list of methods names
And arguments types
Thank you again.
@Cowski, NX automaticall add components to referenceset even if You add line:
CODE
there must be line:
CODE
referenceSet1.RemoveObjectsFromReferenceSet(components1)
and some kind of loop to deselect all components in created reference set.
With best regards
Michael
@niedzviedz,
Good point. If the option to add all components automatically was turned on at the time of ref set creation, it will contain the components. These will need to be removed if this is not desirable. There is an option in customer defaults that will disable the 'add components automatically' option for new reference sets. Personally, I like to disable the 'auto add' option as it gives me more control of what is added and when. If you turn on the option later, it will ask you if you want the components added; however, if you turn off the option after creation, it will not ask you to remove the components.
Cowski I'm very thsnk you.
I'm turned of this preference aldo.
I tested the journal above
And its run ok withoud adding
Components.
But in other journal that merge two refsets
But it works only on objects that are not
A components.
To do the merge I use the ask members
And add members.
So I do not understabd what is the
Problem with refsets and componentd.
@Cowski,
I only use 3 type of reference set: True, false and sometimes DWG for drawings, so I have this option on. For False I have journal to select which body I wanna add. For all 3 I have modified my template.
I think of some kind of loop:
CODE
For each component1 As NXOpen.Assemblies.Component in ...
referenceSet1.RemoveObjectsFromReferenceSet(component1)
next
But what to put after in? I tried few options, but all generate an error.
With best regards
Michael
Cowski you are right. When the customer defaul auto add comps is set to on
So I added a remove object
And thst works ok.
Thank you.
What version of NX is this and why do you do this ?
Tomas
Hi Tomas and thank you.
Is nx11.
I succeeded to got it.
The journsl do a copy of an existing
Ref set.
Did you try just turning off that function Customer in Defaults?
Bob
I don't do that for two redions
1 its our company ddfault.
2 I want my journal to work in that
Option off or on.
Thank you.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
