Retrofitting a vertical tank to receive a dimple steam jacket 1
nejenrod
Chemical
Specs:
Vertical Atmospheric Storage Tank
Built 7/14/1969
Shell- 20-91/2" seam to seam x 120"I.D. x 3/16" thick
Bottom Head- 120-3/8" O.D. x 1/4
Top Roof- 85.7 sq. ft. x 3/16
All three components are 304 s/s
The bottom head is welded to (8)4" Sch 40 pipe c/s.
New project is to store raw material that must maintain a temperature of 375oF.
The project team feels internal coils or half round jackets are not an option.
They want to weld a dimple steam jacket to encompass the shell and bottom head.
Question:
#1 Can the thin shell plating handle a dimple jacketing welded to it?
#2 Does maintaining that high heat create problems for the 304 s/s?
#3 Is there a better way to heat this tank?
 https://files.engineering.com/getfile.aspx?folder=53991c81-5947-49aa-ac7c-406e666b2e69&file=Test_Tank.tif
I haven't dealt with retro-fitting a dimple jacket onto a vessel but it doesn't seem like a good idea. The jacket vendor or someone will have to tell you the wall thicknesses are sufficient. A pressurized jacket would be an external pressure on the tank that it wasn't designed for. The temperature rating is also much higher. I'd be inclined just obtain a new tank that comes with a jacket. Otherwise retrofitting an internal electric heater may be a viable option.
