Contact US
API526 (Rating clarification)
Can anyone clarify my below doubt,
Example: The orifice "3K6" has a minimal starting rating from 900x150,if it is suitable for pressure rating of 900x150 why it is not available with 150x150,300x150...etc, ratings?
Thanks in advance.
RE: API526 (Rating clarification)
IMO, the relief capacity of the PSV with different orifice sizes of the same pressure rating may be overlapped with each other. For example, the capacity of valves 3"K"6 CL.600x150 or 300x150 may be covered by other orifice size of valves, such as either "J" or "L" orifice valves of the same pressure rating class.
Ok Noted,
1. But here 3K6 is a unique size, i.e. No other orifice has this same inlet/outlet size (3x6) per API 526.Hence for this case we cannot overlap it with other orifices unless/untill I change my inlet/outlet size.
2. Can you also clarify what are the deciding factors that links valve size with its rating in API 526.Is it purely due to pressure?
Thanks in advance.
IMO, the valve sizes listed in API 526 could be decided together by the API Committee and the Manufacturer. In my opinion, the Code is reviewed periodically, and can be updated if necessary.
Noted,
Thanks for spending your time.smile2
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
