dadomago75
Hi all,
I have a complex model with a weird shape that gives me problems.
I managed to run the Modal analysis using Eigenvalues algorithm but the mass participation ratios comprise a big component of RX RY.
According to ETABS analysis reference manual UX UY UZ RX RY RZ are about the center of mass whatever that means.
I am not expecting RX or RY.
So what I did is to model a 3 storey structure regular in plan and elevation doubly symmetric with a wall box centered to the slab.
5 kPa UDL over the slab.
I setup 3 models with the following results:
Columns only
Columns and walls
Walls only
The columns only is obviously too flexible and all the mass is activated by the first two modes that are translation.
The other two are pretty similar as I would expect. They both have in common the first mode as torsional.
This worries me because the structure is doubly symmetrical and the center of mass coincides with the center of stiffness. I therefore not expect any torsional mode.
Has anyone came across this problem and investigated it?
Davide
Columns only
Columns and walls
Walls only
Davide
