one-single phase load on a three phase panel/transformer question
Simple question.
3-phase panel 4-wire 480/277.
I have a two wire resistive load 1000 watts@480VAC connected to L1-L2.
NO OTHER LOADS CONNECTED YET, nothing connected to neutral, nothing connected to L3
question
inside the wye connected transformer feeding the panel is one coil supplying 500KVA and one other coil supplying 500KVA?
RE: one-single phase load on a three phase panel/transformer question
Each coil, winding or phase is supplying 500 Watts.
Each coil is supplying 0.577 KVA.
Bill
"Why not the best?"
Jimmy Carter
Each coil in the transformer that supplied the load is taking 577.35 VA
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
White Paper - Medical Device Design Control
Medical device product development is a highly integrated and regulated process. Implementation of a requirements tracking solution requires attention to a variety of nuanced topics. When presented with the task of tracking the many concept relationships in a project of this type, the initial software solution of choice tends to be a two-dimensional text systems. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
