Can 56-foot span steel beams be field spliced at the mid-length without welding, by using bolted splice plates to the flanges, and I suppose the same would have to be done to the web to take the compressive force in the web above the neutral axis as well as the web shear? Right?
Are the flange splice plates to be designed for compressive force only, or do they have to take any moment as well, and if so, how to calculate that moment?
The welding would have to be done in stages, some at the top flange, then some at the bottom flange, then back to the top flange, etc. to avoid warping the beam as the weld cools. Is there any document that specifies this procedure and how many stages it must be done in?
I expect field welding would be very very expensive and slow. Right?
