Okay, I'm getting very confused with array and Mathcad. Can anyone clear this up? Thanks.
USER2018
1
I am trying to compute some average values of resistivity for soil volume. That means I need the average values of certain dimensions in an array. I'm having trouble with this, as the attached file shows. I need to compute the average of the first and second values in a column, and I'm not sure how to do it.
Can you please help? I'm attaching a Mathcad file for you to look over if you wish. (Note: I need to take the average of a 0 row and a 1 row value, then assign it to a 1 row in an array.)
Thanks.
 https://files.engineering.com/getfile.aspx?folder=6d12af22-ed35-4442-b769-0f868017d00c&file=RESISTANCE3.xmcd
need to layup calc properly as one cannot see which array you are trying to use/access
I don't understand your problem; you seem to be able to use and manipulate the array indices, so what exactly is the problem?
answer[i,j := (row[i,j] + row[i+1,j)/2
TTFN (ta ta for now)
