OOF2 thickness of a stone and mortar wall
pls91
IT
hi guys,
I'm a new user of OOF2. I want to lead a linear static FEM analysis of a wall made of stones and mortar by using OOF2.
I've already defined my model in terms of materials, boundary conditions and load.
btw, among the input data, I didn't find a field where I could put the thickness of my wall. is it possible take into account the thickness of my wall?
thanks
You are aware that this is the Abaqus forum?
@Mustaine3 I'm sorry, I've searched in this forum "OOF2" and I've seen that there were other questions about this topic, for this reason, I've posted here.
Let me know where I can move this question to a more appropriate section, thanks :)
Never heard about this before, so I do not have a clue.
If you are looking though to generate an Abaqus input file from this software, then perhaps someone could help.
Give some more info then; do you have an input file and is it missing section properties (it is not clear what you mean with your post)? is it a brick/3D mesh or a shell/plate model??…..
If it is more related to OOF2 GUI and that it does not give the option to assign sections, then it is better to talk to the developers, or if they have a forum.
(I assume this is the case, but I was not sure 100%).
In any case more info and explanation is needed, in order for someone to help.
PS: A quick look in the manual (section, 2.5 - mesh), shows that it solves for plane strain and stress, so effectively the thickness dimension seems to be removed.
