ETABS TO SAFE MODEL REACTION INCONSISTENCIES
Good morning everyone,
I am currently working on an ETABs model, and when transferring over to SAFE, the reactions for each load case have minor inconsistencies. Most roughly in the 4 to 6 kip range. This occurs for every load case (DEAD LOAD, SUPER IMPOSED DL, LL, WIND, ETC.). Does any one have any insight into why this may be occurring? Thank you in advance.
RE: ETABS TO SAFE MODEL REACTION INCONSISTENCIES
I've seen this before with another software (RISA). I can't say for sure that the issue is the same, but maybe it is.
If the solution you run in ETABS matches the solution run to get your SAFE reactions, then the results should be identical right. So, what could be different:
1) 2nd order effects: Is a P-Delta analysis included in your ETABS run. Does it match the way P-Delta is considered when the program produces the SAFE reactions?
2) non-linear elements: Do you have any tension only or compression only elements or such in your model? If so, how are these treated when the SAFE reactions are calculated?
3) Stiffness adjustments for Direct Analysis Method or concrete cracking or such. If these are handled differently between the two analyses, then the reactions would probably be different.
Is this a model where you are replacing existing reactions with new reactions?
If so, there are some key buttons to press in the SAFE import screen.
Let me know if this is the case and I may be able to help.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
