Export STEP file from Creo to Solidworks
DKrol
Petroleum
NO
Hi guys,
I have received a STEP file that had been exported from Creo. It is going to be used to run a flow simulation in Solidworks.
When I import the file into Solidworks and run geometry check I get plenty of zero thickness geometry errors.
Do I have to fix all the errors on part level or is there any faster way to handle the problem?
Why do I see so many zero thickness errors after importing the file into Solidworks?
Thank you in advance for your help!
STEP is a neutral format of geometry data and supported by many software applications. You can try to load the STEP file using another CAD/CAE application, to see if the zero thickness exists.
You also can double check your thickness definition from the Creo, and set a thickness value to the specific bodies if the zero thickness indeed exists.
