Sizing dewatering pump from runoff calculations
How do you size a dewatering pump once you have the site runoff calculations for the corresponding watershed? I need to size a pump for a 100-year event in order to prevent a flooding condition into a building. I have assumed a 5 minute tc value (watershed is small) for a 100-year rainfall intensity and gotten a flow rate. How do I then best size the pump using this calculation? Do I need to use a different tc value in my runoff calculations to get something more appropriate to size the pump in gpm? Assume minimum to zero sump volume at the pump.
Any help would be greatly appreciated. Thanks!
RE: Sizing dewatering pump from runoff calculations
Unless you have enough storage to attenuate the peak, your pump will need to be able to handle the peak runoff, otherwise the pump chamber will.overfliw.
Peter Smart
HydroCAD Software
www.hydrocad.net
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
