NX NASTRAN Topology Optimization
iprestes
Aerospace
Sep 11, 2018
3
I am a new user of the Topology Optimization NX Nastran (version 12.0).
I did the Siemens tutorials and tried to reproduce the same steps for another geometry that I created. However, the optimized geometry's displacement is way too high. It results in 25 mm, although I set a constraint for it to be not hight than 3 mm.
Also the material density results make no sense: if I use a Lower Bound equivalent to 0.04 some random meshes (which are not even connected) appear; if I set the lower bound to 0.03, the whole geometry appears.
Does anyone know what is happening?
Thanks!
 https://files.engineering.com/getfile.aspx?folder=6818cbe7-3b82-4858-ba47-96f52a36e951&file=material_density.png
0.514 mm against 0.435mm on the original design.
However, I get the same problem with the material density. With a lower bound of 0.81, there is no connection between the parts; with a lower bound of 0.79, I get the same geometry as the original. With 0.8, I get a kind of a porous material, but doesn't make any sense.
