Hello Everyone,
I recently joined this forum.I have a question. I am designing a crushed stone ringwall foundation for 102 m diameter 24 m height EFR tank cone bottom .
I did a bearing pressure check for the ringwall . The ringwall is 1.3 m above grade and 2 m below grade. Slip Failure analysis was done by an geotech expert and he recommended to go 2 m below the grade.
My question is for bearing pressure check I am getting negative pressure due to the eccentricity of the tank loads acting on the ringwall bottom. The ringwall bottom is 12 meters wide. Since this is the first time I am designing a crushed stone ringwall foundation and that too for such a huge diameter tank, I wanted to check if my approach towards this calculation is correct or not. Attached is a picture of the loads I have considered.
Any help would be appreciated.
