In-situ Horizontal stress calculation from Pressuremeter test data
Greetings to All,
For pressuremeter test (prebored pressuremeter test) interpretation (undrianed shear strength) the reference state has been taken as horizontal earth pressure (P0) at that test depth for all strain calculations. This is the basic assumption taken by A.C. Palmer (1972), Ladanyi (1972). Who gave the mathematical expressions for calculation of undrained shear strength of clay, as slope of corrected pressure vs. Ln(del v / V).(I will attach these papers if anyone wants to read.)
del V = V(measured)- V (at P0 )
V = probe core volume + measured Volume at P0 + del V
So, here my doubt is in my calculation of P0 if am following iteration method given by A. MARSLAND AND M. F. RANDOLPH (1977) i am getting a P0 of 2368 kPa and undrained shear strength of 557 kPa at a depth of 30 meter depth.
But if i will take simple starting point of thr elastic linier portion P0 will be 590kPa and undrained shear strength of 825 kPa.
So, please guide me how can i fix the reference volume so i can correct shear strength of the soil and how to ensure the P0 values were reasonable.
I am attaching the curves below. If you need anymore info please reply below.
Many many thanks for your concern.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
