A challenge for Mathcad Prime 5.0
PNachtwey
I am still waiting for PTC to get their act together. I have 25 years of Mathcad files.
I stopped upgrading at Mathcad 13. I use the symbolic solver a lot and PTC ruined it when they made Mathcad 14. Now I use Mathematica that is expensive. I also use Python with sympy to do symbolic processing.
So here is the challenge. Given 3 points solve for the center of the circle and radius to the 3 points.
This problem is simple enough to be entered in a few minutes.
Code:
from sympy import symbols, init_printing, sqrt
from sympy.solvers import solve
""" find the center and radius of a circle defined by three points """
init_printing()                         # enable pretty printing.
x0, y0, x1, y1, x2, y2, xc, yc, r = symbols('x0, y0, x1, y1, x2, y2, xc, yc, r')
eq0 = (x0-xc)**2 + (y0-yc)**2 - r**2
eq1 = (x1-xc)**2 + (y1-yc)**2 - r**2
eq2 = (x2-xc)**2 + (y2-yc)**2 - r**2
s = solve([eq0, eq1, eq2], (xc, yc, r))
# there are two solutions, r > 0 and r < 0
xc0, yc0, r0 = s[0]
print("\nxc0 =",xc0)
print("\nyc0 =",yc0)
print("\nr0  =",r0)
xc1, yc1, r1 = s[1]
print("\nxc1 =",xc1)
print("\nyc1 =",yc1)
print("\nr1  =",r1)
Here is the output. There are two solutions because r can be positive or negative and still be valid as far as the problem goes but only the positive solution works.
Code:
xc0 = (x0**2*y1 - x0**2*y2 - x1**2*y0 + x1**2*y2 + x2**2*y0 - x2**2*y1 + y0**2*y1 - y0**2*y2 - y0*y1**2 + y0*y2**2 + y1**2*y2 - y1*y2**2)/(2*(x0*y1 - x0*y2 - x1*y0 + x1*y2 + x2*y0 - x2*y1))
yc0 = (-x0**2*x1 + x0**2*x2 + x0*x1**2 - x0*x2**2 + x0*y1**2 - x0*y2**2 - x1**2*x2 + x1*x2**2 - x1*y0**2 + x1*y2**2 + x2*y0**2 - x2*y1**2)/(2*(x0*y1 - x0*y2 - x1*y0 + x1*y2 + x2*y0 - x2*y1))
r0  = sqrt((x0**2 - 2*x0*x1 + x1**2 + y0**2 - 2*y0*y1 + y1**2)*(x0**2 - 2*x0*x2 + x2**2 + y0**2 - 2*y0*y2 + y2**2)*(x1**2 - 2*x1*x2 + x2**2 + y1**2 - 2*y1*y2 + y2**2))/(2*(x0*y1 - x0*y2 - x1*y0 + x1*y2 + x2*y0 - x2*y1))
xc1 = (x0**2*y1 - x0**2*y2 - x1**2*y0 + x1**2*y2 + x2**2*y0 - x2**2*y1 + y0**2*y1 - y0**2*y2 - y0*y1**2 + y0*y2**2 + y1**2*y2 - y1*y2**2)/(2*(x0*y1 - x0*y2 - x1*y0 + x1*y2 + x2*y0 - x2*y1))
yc1 = (-x0**2*x1 + x0**2*x2 + x0*x1**2 - x0*x2**2 + x0*y1**2 - x0*y2**2 - x1**2*x2 + x1*x2**2 - x1*y0**2 + x1*y2**2 + x2*y0**2 - x2*y1**2)/(2*(x0*y1 - x0*y2 - x1*y0 + x1*y2 + x2*y0 - x2*y1))
r1  = -sqrt((x0**2 - 2*x0*x1 + x1**2 + y0**2 - 2*y0*y1 + y1**2)*(x0**2 - 2*x0*x2 + x2**2 + y0**2 - 2*y0*y2 + y2**2)*(x1**2 - 2*x1*x2 + x2**2 + y1**2 - 2*y1*y2 + y2**2))/(2*x0*y1 - 2*x0*y2 - 2*x1*y0 + 2*x1*y2 + 2*x2*y0 - 2*x2*y1)
The generated code is much more efficient that Mathcad 13. Notice I can use text which is very convenient for educational purpose or solving math for a webpage with a java script interface. Python will also generate LaTex for pretty printing on web pages.
What can Mathcad Prime 5.0 do?
Peter Nachtwey
Delta Computer Systems
