Vibration on Air Atlas Copco compressor
RE: Vibration on Air Atlas Copco compressor
It would be nice to look at a spectrum for both the full load and low load condition to identify dominant vibration frequencies. Measurement of high frequency vibrations are difficult to measure and compare to available criteria. I assume this is a dry compressor with timing gears and possibly anti-friction bearings. Has you identified the pulsation harmonics, gear tooth harmonics and possible bearing fault frequencies in your data. If you have not, then how can you say it is okay to run or not?
Walt
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
