How to create the opposite surface using Through Curve Mesh 1
Kadazaras
CH
I have tried for 2 days to find the answer to this problem (which looks very simple).
I am trying to create the opposite of this simple model. I have tried changing the direction of Primary Curves and Cross Curves but nothing is working.
Thanks in advance for the help.
Trim your primary curves so they are not complete circles.
Thanks a lot for the help Kneubaecker.
Is there a way of doing it without cutting?
Use stop at intersection when selecting the primary curves or cross curves (see pic below).
The attached video shows how it works.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
Works perfectly Anthony.
Thanks a lot, I was going crazy.
