DraftSight Groups not showing up
Program was running just fine then one day all of my groups were not there. I tried to make new ones and it said there was already a group made. I cant select the groups just the single entities. Not sure what happened any ideas?
RE: DraftSight Groups not showing up
I might not be too much help as I don't use groups myself, but I know where you can see a list of groups in the drawing file.
If you type in "_clean" and check the "Show referenced entities" button you can see the list of groups.
I did some research and also came up with a command line varient to see the list: group/Name/?/*
Found this "gem" in the help file:
Further digging found this which I think should fix your dilema.
Controls the selection of Groups and associative Hatches. The variable lets you select all member entities of Groups together with a single click. It also lets you simultaneously select hatch patterns and their associated boundaries.
Values
0 Does not select Groups or associative Hatches
1 Selects Groups
2 Selects associative Hatches
3 Selects Groups and associative Hatches
Properties
Type Integer
Range 0 | 1 | 2 | 3
Default 1
Status Read / Write
Saved In the user's profile
