Import 3d Autocad to Abaqus
Hello people,
I am sorry if this thread shown up again in the forum, is my first attempt to start a thread here.
Since I am pretty amateur in using the Abaqus software I have a serious issue importing a 3d file in abaqus.
What is the proper procedure of doing it? By importing as dxf and sketch options in Abaqus is not working so I guess the only way is to import by parts, saving the 3d model as i.e. a .sat file. The frame is attached, is a simple steel frame.
Would be great if I receive some help. Thanks in advance!
RE: Import 3d Autocad to Abaqus
Export .sat or .stp/.step and import that into Abaqus/CAE.
you are an expert in AutoCAD, .sat and Abaqus, which is well nigh imposssible for most of us.
I do the following things to overcome these difficulties,
1. Prepare complex dwgs save as dxf and then import these as sketches in abaqus. Then use the Abaqus methods to generate parts, assemblies etc.
If I need to generate a complex part, I generate simple parts firsts, assemble them, convert to the part I deesire and delete the simple parts.
2. Import complex 3D .sat files only as reference and build sketches or parts in anbaqus using these imported .sats . So the imported .sats files are source of geometry only and nothing else.
I hope this advice is helpful to you.
